Hi there! Quick question. I am looking to grab the images in this sequence (NSFW)
http://www.monitor.hr/belle/0404/040401.jpg
Note that the directory name (in this case "0404") is also repeated in the filenames it contains. The range goes from 0001-0799 (approximately)
I considered entering the URL like this:
http://www.monitor.hr/belle/[0001-0799]/[0001-0799]01.jpg
However it would need to search about 640,000 URLS, which is really inefficient.
What would be the easiest way to have PicaLoader repeat the variable?
Also, if anyone has a link to a tutorial for general scripting that might help me next time, I'd love to learn more. Thank you!
Sequential Image DL'ing: how do I repeat a variable?
Start URL:http://www.monitor.hr
Check Search sequence pictures
HTML Parser Script:
if (HTML.Level==0) then
local i=1;
while i<9 do
local j=1;
while j<15 do
local url=string.format('http://www.monitor.hr/belle/%02d%02d/%02d%02d01.jpg',i,j,i,j);
AddLink(url,HTML.Url,HTML.Title,'',HTML.TaskID,0);
j=j+1;
end;
i=i+1;
end;
end;
That's all. you can adjust 15 in while j<15 do to a number less than 99, maybe you can get more pics.
HTML Parser Script:
local i=1;
while i<9 do
local j=1;
while j<15 do
j=j+1;
end;
i=i+1;
end;
end;
- moni.jpg (107.23 KiB) Viewed 12706 times
- moni.plt
- save to your disk then select menu->Task->Import Task(s) to import to your project.
- (9.93 KiB) Downloaded 520 times
This may help some more.
The pictures have a main ref like year month and a sub ref like year month day number.
so http://www.monitor.hr/belle/0702/070228.htm means :
belle / 07(year)02(month)/07(year)02(month)xx(day).jpg
Y=97 to 08 in 97 the month starts with 03
M=01 to 12
D=01 to 31 max
Maybe this will help to rewrite the script.
M=01 to 12
D=01 to 31 max
