Mark
PicaLoader 1.40 freezing up after downloading
I have a problem with PicaLoader 1.40 freezing up after downloading a little more than a thousand images. IÆm not able to pause or cancel the session and I can only close the program out from the administrator part of windows XP. When this happens my CPU usage is also between 96 percent to 100 percent usage. But if I let it sit for hours it doesnÆt change. Has anyone else experienced this problem and if so do you know why?
Mark
Mark
I ran some of the sample projects and downloaded more then a thousand images without it freezing up. IÆm wondering if it is the web sites that IÆm trying to download from or is it the settings I have set up for those projects. If someone could please test the sites for me and see if they work for you.
http://photo.net
http://onemobelplace.com
Mark
http://photo.net
Mark
Download pictures from photo.net
I had try http://photo.net, it works fine, I had already got more than 1000 pictures.
1.Uncheck "Support J/VB/JavaScript", this is not necessary for this site.
2.Add "community;bboard;google_ad" to Page URL Exclude Filters.
- photos.plp
- The project file
- (9.29 KiB) Downloaded 772 times
Same problems
I have to leave the jsp dynamic etc setting on for the site I am working on but I have to pause and reset the project after about 100 or so images. It just gets too slow and then stops downloading altogether.
Is there any thing that I can do about this?
