Ummm WTF
plaztik-
Before you go about making any tasks, pick any of the default filters in the list.
Then manually change it to a minimun horizontal and vertical size of 300.
All other fields should be set to (zero).
This will set Picaloader to reject any photos below 300 x 300 resolution as a default.
I chose 300x300 because I think that anything lower is too small to keep.
Hope this helps...
Hope this helps...
