i want e option tho scan my drive for duplicate pictures
Users can post any suggestions regarding new features here for discussion. Don't forget to create a poll so that other users can vote on whether the suggested feature is needed.
spider
Post by spider »
i want e option tho scan my my hardrive or folder for duplicate pictures i have downloaded like 2567 site at the moment so i have elot of duplicate picture en that u can scan folders for the same name en u can put the files with the same name in one folder like i have downloaded two site site A en site B en site A have folder nature en site also the contents of those folder are put thogether sorry for typos im dutch not engels
dbhome
Post by dbhome »
try clonespy a free dup checker for all kinds of files
Overview
Why was CloneSpy written?
Do you often download files from the Internet? Is your hard drive crowded with these files? Have you ever asked yourself which files you have downloaded more than once? Perhaps you have burned files to a CD and retrieved them again? Do you want to find these files and eliminate the duplicates? Maybe you want to find duplicate files without checking your entire collection of backup CDs every time? Then CloneSpy is the right tool for you!
What can CloneSpy do?
CloneSpy can help you free up hard drive space by detecting and removing duplicate files. Duplicate files have exactly the same contents regardless of their name, date, time and location. Also, CloneSpy is able to find files that are not exactly identical, but have the same file name. Perhaps you have different versions of a file and you want to find all of them and remove the older versions. CloneSpy can also find zero length files. These are files that have no content.
With CloneSpy you can process files which
are duplicates
are duplicates and have the same file name
have the same file name and (approximately) the same size
are zero bytes long
CloneSpy offers you a complete mechanism for determining which duplicate or same-name files should be removed. It is also possible to leave this decision up to the individual user.
CloneSpy can handle equal files by
deleting redundant files
moving redundant files to a specific folder
exporting a list of all equal files without removing any files
deferring file operations on redundant files to a batch file where you can apply arbitrary file operations
With CloneSpy you can build checksum files from files on CDs (or even on hard drives, etc.) and use them to check whether these files already exist on your system. The checksum files will prevent you from having to play DJ every time you search for duplicates!
If you are using CloneSpy for the first time, please take the time to read the Important Note and the Quick Start section.
the main site is down except for downloads so above is taken from its help file
download here or below (please to save this sites bandwidth use only if the org link is dead or very slow)
file below is the org unmodified file and in this form allowed by the author to be redistributed
cspy211.zip
same as from the site but incase its slow or down this is the exact same file
(608.09 KiB) Downloaded 909 times
D_D
Post by D_D »
Find and delete duplicate files and folders by Dupe Checker PRO
studio308
Contact:
Post by studio308 »
Duplicates may not be 100% same, but very similar, if downloaded from different sites in different size and dimensions. You should use ImageDupeless, the another great thing by Russians. It can find images to 12% different in binary level. It can found with this method 99% of duplicates.
Listen to WMRI...
Give me some points, please just visit http://www.jetune.ru/us119].
