Hello,
I am interested in loading a whole set of images, but I am new to this program and would love to get some help.
The domain format is:
Help with domain.com/dir/100000/display
The number between dir/ and /display is the image number I want to grab. The problem is that its a dynamic script so if a number doesn't exist a error page shows.
I would like to download everything from 100000 to for example 100010 which would be max. 10 images (possibly less cause some numbers are no images).
What would I have to setup to do exactly that without following links - meaning if its an image, download it - if not, inore and go to the next number.
Thank you
Re: Help with domain.com/dir/100000/display
try create a new task and enter domain.com/dir/[100000-100010]/display as start url.
check Main menu->Help->Contents->Using PicaLoader->Batch download numbered sequence URLs with one task
