HowTo - Download largest size pics from DeviantArt
Using PicaLoader as DeviantArt Downloader!
This article is combine of:
how to download gallery from deviantart.com
and
download from deviantart
First, save attached .plt file to your computer, run PicaLoader, open your project or create a new project, select main menu->Task->Import Task(s) to import the .plt file.
Then enter the start URL by yourself:
This task template can work for these case:
1. Download pics by DeviantArt browse categories, e.g. you want download all pics in category "traditional/drawings/people", the start URL should be:
http://www.deviantart.com/#catpath=traditional/drawings/people&order=9
2. Download pics by user, just enter the user gallery URL, e.g. for user racca:
http://racca.deviantart.com/gallery/
3. Download search result, e.g, you want download search result of "rose mary", the start URL should be:
http://www.deviantart.com/#order=9&q=rose+mary
4. Download a user's collection, just enter the collection's URL, e.g:
http://matt-kane.deviantart.com/favourites/?3138913#_3138913
If you want also download "Mature Content" from deviantArt, just open deviantArt with IE (must use IE, not firefox or other browser), login with your acount and password (if you not yet have, just sign in, it is free), then change your profile like attached picture show. Keep IE open, run PicaLoader and start downloading.
that's all.
if any questions about download pics from DeviantArt, please reply this article.
Turn off "Mature Content" filter.
deviantart.plt
Task template for DeviantArt
(9.93 KiB) Downloaded 3676 times
tuan11
Post by tuan11 »
YEAR!!! you are great!! :P
but i find another problem
my start URL is:http://www.deviantart.com/#order=9&q=oasis
now the pictures i downloaded are about oasis, but just can download some of them, can't download all the oasis pictures!
tuan11 wrote:YEAR!!! you are great!! :P
have u switch to report pane and check the error report?
you can post a missing pic's URL here, let me have a test :)
tuan11
Post by tuan11 »
oasis search result:
the pictures are downloaded:
11190 pictures but 60 pictures are downloaded!
OASIS.plt
(9.93 KiB) Downloaded 8795 times
Sorry, I upload a wrong version plt file. please re-download the plt file. :oops:
tuan11
Post by tuan11 »
oh ,haha,great great very great,works very good!
thanks for your great help!
o(∩_∩)o...
:D :P
great help with this site
finnegc3
Re: HowTo - Download largest size pics from DeviantArt
Post by finnegc3 »
Thanks for creating such a great piece of software!
I am having a problem with deviantart though. I can download an artist's main gallery but I can't download any of their alternate galleries.
For example I can download all of the images from here -
http://assesina.deviantart.com/gallery
but this does not include the images from the OLD FAKE STYLE gallery here -
http://assesina.deviantart.com/gallery/#OLD-FAKE-STYLE
And using this as my start URL does not help. Is there a way around this? (thanks again for the great program)
They changed the gallery browse mode.
I had renew the .plt file, please download the new .plt file and try again:)
finnegc3
Post by finnegc3 »
Brilliant! I'll try that after work and let you know how I get on. (ps Can users write their own plt files, and if so what language is it?)
finnegc3
Post by finnegc3 »
That works a charm! Thanks for the help
8)
XionYazuka
Post by XionYazuka »
Thank you so much! This saves me so much time and I deeply appreciate it.
I am having a problem with downloading stuff from the "scraps" folder though, I tried for hours to get it to work on my own but i'm painfully uneducated in how to set the options. Basically I can grab everything fine from;
http://nashya.deviantart.com/gallery/
But I can't download anything at all from;
http://nashya.deviantart.com/gallery/#_browse/scraps
Which is like another 66 pictures.
Also...some things in galleries(not this one) are only available at full resolution from the "download" button and it looks like Picaloader can't grab links from that button. Is there anything you could do about that? An alternate .plt for scraps would be super duper awesome. Don't worry too much about the whole download button thing if it's too much trouble though.
Once again, thank you for the .plt you did provide!
try the newest deviantart.plt :mrgreen:
XionYazuka
Hey Koala,
I gave that .plt a try and it's still only grabbing from the main gallery and nothing from the scraps gallery.
Edit: Was that the "download button" version? If so, I think it worked. Let me try it some more.
Edit 2: The "download" version(deviantart2.plt) of the .plt definitely works, just tested it out. It does seem to have a lot of error issues(probably caused by DA) where I have to download 3+ times to grab the entire gallery, still, it's very useful so thank you! But yeah, if that was intended for scraps too it didn't work.
Edit 3: It seems to have random "can't get file" errors for random files in the gallery. Some files it just plain won't grab...for reason I can't explain. It just won't recognize them.
Edit 4: Logging in manually seems to get rid of the "can't get file" errors but it still misses a couple of "download" links.
There are 36 download enabled links here;
http://ryo007.deviantart.com/gallery/
And it only grabs 32, give it a try yourself to see if you have the same issue.
Edit 5:(jeez, lol) Well, I tried the new .plt (with manual login) with a bunch of different galleries and it appears to be working fine now. I haven't gotten anymore errors and it appears to grab the highest resolution(download enabled) pictures while defaulting to the "full size" images when no download link is available. The only issue i'm having is with the above linked gallery where it won't grab certain things for whatever reason, it's a mystery to me since 20 other galleries have worked flawlessly now.
Also, as mentioned before it's still not grabbing anything from scraps so that's the only thing left now. Thank you once again for your efforts Koala, I really appreciate it! :D
XionYazuka
I just had an interesting problem...I was trying to download the following gallery;
http://scarlet-dragonchild.deviantart.com/gallery/
And instead it downloaded the gallery of;
http://dragonchild.deviantart.com/gallery/
So...basically anyone with a "-" in their name is going to cause the issue from what I can see. I tried replacing the "-" with a few different things but nothing worked.
