Here's how the site works:
For any given person's set of images, on the top level, there are multiple pages, each having 6 thumbnails (filename contains ".thumb." in it).
When you click on the thumbnail, you reach a smaller-sized image (filename contains ".sized." in it).
On the page with the smaller-sized image, you click a link labeled "View Full Size", which takes you to a page that contains the full-sized image.
The problem:
I was able to get this to work only once: PL would go through every page, go through every thumbnail, and download each full-sized image...
...but when I tried it after that with a different person, PL would stop parsing the page before even reaching the thumbnails. PL goes through every page of the person's set, but doesn't go through the thumbnails anymore. I tried going back to the original person's images I had downloaded, but that didn't work for me anymore. I also tried removing my ".sized." and ".thumb." constraints, but that doesn't work anymore either.
I'm pretty sure my Option set is right; I'm wondering if there's some sort of cache that PL is keeping that isn't been renewed each time I start the project, or if anyone had any other approaches in creating the Option set.
Parsing lazygirls.info
yes i know you need to log on (use log on manualy and enter lazygirls.info/login.asp as url). This site sure dont make it easy
I will try another project.
Is there a way to make picaloader increment a URL with 6? Ie, 0, 6,12 etc? [0-100] makes it go to XXXX-1 XXXX-2 etc when the pages acctualy are xxxx-0,xxxx-6,xxxx-12 etc.
