While putting together a project for www.desktopia.com I came across a wierd problem. I created 3 tasks, one for Actresses, 1 for Female Models and 1 for Asian Models. I started with trying to download the Asian Models and after some trial & error (Aborts) with the filters I got it set up to where I liked it. I then noticed that all the images filenames started with "imagefolio####.cgi" & the folder structure on the disk was wrong, all the files were in a wrong single folder. I had specified to recreate the structure of the web site. The file extension was also CGI instead of JPG! I had no problem viewing them in PL but since the file extension was wrong it caused viewing problems with other applications. I then tried the other two Tasks and they worked OK....
After some playing around to no avail, I deleted the Task, exited & reopend the Project, recreated the Task and it then worked OK.
I'm not sure why PL was doing this!
Filename oddity!
New!
With v1.47, you can define the filename by yourself:)
