1) It would be nice to have the ability to launch or redirect Internet Explorer to the web page on the Options Tab URL. If IE isn't running then launch it, if it is already running just redirect it to that web page unless holding down the Shift Key which would open the page in a new IE window.
2) Some kind of status be added to show a count of what's checked at the bottom of the Thumbnail window (Main Pane).
3) When multiple images are Checked and you do a Delete Checked, I'd like to see a count of what's checked be added to the "Are you really sure you want to delete these pictures?" dialog box. Only after you say Yes and get the resulting next dialog box do you see the # of files that were deleted.
4) Undo Delete option for those times that one screws up.
5) An option to Keep or Delete the images when doing a "Remove a Task".
A few more suggestions
To clarify #1:
I'd just like to be able to double click or have a button added or someway to have Picaloader display/open whatever webpage address is in the URL field in the systems default web browser.
For example, double clicking on the label "URL:" would display or open whatever website address is in that field in Internet Explorer. If "http://www.vowsoft.com/index.htm" were in the URL field and I double clicked on it or on URL: your website would appear in Internet Explorer.
Or maybe adding a button called "Open Webpage" or "Goto Webpage" would be more better. Clicking on it would open that webpage.
Hope this makes more sense!
