I am using a trial install of PicaLoader and having trouble downloading this site
www.supermodelforever.com
I think it is because of the webpage was made in Frames. I'm I just not getting the gallery to download right because of the wrong opitions or is it because of the frames?
I would appreciate any help on this.
~Spanilizer
I'm having trouble with frames
I like my images organized so I created a Task for each person.
The Tasks URL uses batch sequence numbers so you'll have to make adjustments as the site grows. The numbers inside the brackets represent the number of pages for each person.
I deleted the tasks for the categories or weekly pics because of the upload file size limit of plp files
- Supermodel Forever.plp
- (221.42 KiB) Downloaded 2245 times
Spanilizer
Spanilizer
Basically just Right Click & choose Properties all over a page and look at the Address: field.
For any link, you can usually view the address at the bottom of IE if you have the Status Bar checked (View menu). You can copy that by Right Clicking on it and choose Copy Shortcut. Even better in PicaLoader you can drag & drop a link onto the PL Drop Box and PL will create a new Task using that URL address and the other Project defaults you have setup. The Project defaults can be seen & configured by selecting the Project Name and the Option Tab. Every new task you create will then use those defaults. This will save a lot of time if you have a lot of filters, you won't have to copy & paste them all the time but you may have to modify them depending on the situation & the web site.
