Only downloading thumbnails
Balmouk
Post by Balmouk »
I am trying to download all the larger images from a site and can't get it to work, although the thumbs download. I'm not very good withy computors can anyone help please? I have tried various URL's including this one.
Http://www.villageladies.com/members/index.htm
If you can thanks a million.
dbhome
Post by dbhome »
under profiles you can set it to high res pictures only. if you look on the task window you will see 2 tabs at the bottom tasks/profiles in the profiles tab you change and/or create a custom profile settings min/max dimension's resolution etc
hope this helps you if not reply
