I can start PL, open a project file, enable a task and run it ok. But if you enable another task or even open a different project, the task won't run. You get "Can't get the file" error. Nothing will run anymore until you shutdown PL and restart it. Then the first task runs ok but everything after it fails to run until PL is restarted again!
THIS NEEDS to be FIXED ASAP!
"Can't get the file" in Version 1.49.0629
