Need help with this site..thanks a lot~~
vomitmanx
Post by vomitmanx »
http://www.pbase.com/albertjou/publish
how could I get the pics on the web sites.....
thank you very much!!
there is error message --[Can't create local file]
here
download the attached project file to your hard disk, open with PicaLoader and push start...
my picture folder is c:/my images , you can change it by select main menu->project->properties->picture folder.
albertjou.plp
(14.79 KiB) Downloaded 1096 times
vomitmanx
Post by vomitmanx »
it really works~~~so amazing!!
thanks!!
[/list]
Thanquol
Post by Thanquol »
Hi @ all!
Thanks for this information!
PicaLoader is the first program i found, which is able to download from pbase.com ;-)
But i have a little problem / question
e.g.
The RootURL:
http://www.pbase.com/maribel/
one Gallery:
http://www.pbase.com/maribel/friends
another one:
http://www.pbase.com/maribel/mi_familia ... s_animales
but all pictures are stored on pages like
http://www.pbase.com/maribel/image/45656504
http://www.pbase.com/maribel/image/34231541
and the pictures themselve are on many different webservers and folders!
http://mishami.image.pbase.com/v3/59/47 ... grales.jpg
http://mishilo.image.pbase.com/u35/mari ... nibiza.jpg
I'd like to safe all Pictures in a folder, which is like their galleryname!
-> Folder mi_familia_y_otros_animales
but:
Folder Struct:
Standard Project: Storing pictures into 37 subfolder.... doens't do what i want
Lite Project: doesn't do what i wand ;)
Create a subfolder... almost does it!
Recreate targets website..... does many many folders, but not in the right structure (because of pbase.com's structure!)
I could use the filename options, but the Referrer is alway pbase.com/images/NUMBER and not the Gallerys Name!
I would need the referrer of the referrer ;)
Maybe a solution would be to create many tasks, and every task has its own gallery in it! With the LiteProject Option i could reach my aim ;)
But if there are 100 Galleries on one pbase page.... it's too much work!
Maybe i could write some scripts to write those gallerylinks into a special file (e.g. with a VB Prog, a PHP script... whatever!)
But is there any possibility to import those Links into PL with some special options (like in your file), or the best would be if i could create a plp file with an external program as plain text...
I hope you understand my "problem" :D
Is there any Chance to realise my project?
Thanks anyway!
Greetings from Germany
Thanquol
