How to have more than 2 connections ?
nsing
Post by nsing »
Dear all,
Eventhough i've set the max connections to 50 but it is still limited to 2 connections. I've referred to FAQ question 7 and visited microsoft site to get around it but the registry path doesnt exist in my Windows XP Pro. Can someone please help me ?
What you means "still limited to 2 connections"? please tell me more. And please tell me something about your computer: RAM, CPU, Internet connection, etc.
nsing
Post by nsing »
OS is Windows XP Pro.
My internet connection is 384 kbps.
RAM is 512 DDR.
Processor is AMD Athlon 1700.
When i clicked on the "Monitor" tab, i noticed only 2 connections are being utilized eventough i set my connections to 50. I've read the article by microsoft to get around it but i cant found the registry keys mentioned.
The registry keys mentioned are;
MaxConnectionsPerServer REG_DWORD (Default 2)
Sets the number of simultaneous requests to a single HTTP 1.1 Server
MaxConnectionsPer1_0Server REG_DWORD (Default 4)
Sets the number of simultaneous requests to a single HTTP 1.0 Server
Do you have any idea how i can get around it in Windows XP Pro ?
Many thanks.
Best Regards,
nsing
You means only two connections in working (connecting, downloading) and other connections in "watting..."?
For your computer, I think set connections to 10~15 is enough, because your Internet speed limit to 384kbps, more connections will not speed up the downloading but only spend more memory, CPU time and slowdown your computer.
nsing
Post by nsing »
Yes Mr Admin. You are totally right, only 2 connections running while the rest are waiting. Any tweak for this ? Thanks!
Try this:
Select main menu->View->Options->Download, set "Pause between connections" to 0 seconds.
nsing
Post by nsing »
I've already set the Pause to 0 but it is only utilizing only 2 connections. Please help. Thanks!
Could you please post your project file here or email to picaloader@vowsoft.com?
nsing
Post by nsing »
Attached is my project file. Thanks!
sg.plp
Sggirls Project File
(14.29 KiB) Downloaded 812 times
I had test your project file under Windows XP Home, 512kbps Internet, 512M RAM, P4 1.6G, it works well!
I have no idea.... could you please make a screenshot of monitor view and post here?
Thanks,
nsing
Post by nsing »
Attached is the screenshot. Only 2 connections :(
