Java Script blocking PL?
Posted: Thu Jun 30, 2005 1:29 am
I've been trying PL on laurie-model.com for quite a while, but keep getting errors in the report saying 403:Forbidden. I noticed the following piece of java code when I viewed the source of the main page (after logging in):
I know absolutely nothing about java, but I was wondering if anyone could determine if this site was indeed using code to block the use of PicaLoader. Sure seems like it to me. A few months ago, I was able to get it to work, but now it seems blocked. Stumped on this one.
Thanks.
Code: Select all
<SCRIPT TYPE="text/javascript">
function newImage(arg) {
if (document.images) {
rslt = new Image();
rslt.src = arg;
return rslt;
function changeImages() {
if (document.images && (preloadFlag == true)) {
for (var i=0; i<changeImages.arguments.length; i+=2) {
document[changeImages.arguments[i]].src = changeImages.arguments[i+1];
var preloadFlag = false;
function preloadImages() {
nextupdate_laurie_header_09_over = newImage("../images/nextupdate-laurie-header_09.gif");
laurie_header_07_laurie_header_09_over = newImage("../images/laurie-header_07-laurie-hea.gif");
laurie_header_07_laurie_header_14_over = newImage("../images/laurie-header_07-laurie--11.gif");
laurie_header_07_laurie_header_12_over = newImage("../images/laurie-header_07-laurie--12.gif");
laurie_header_07_laurie_header_10_over = newImage("../images/laurie-header_07-laurie--13.gif");
laurie_header_07_laurie_header_11_over = newImage("../images/laurie-header_07-laurie--14.gif");
laurie_header_07_laurie_header_13_over = newImage("../images/laurie-header_07-laurie--15.gif");
laurie_header_08_laurie_header_09_over = newImage("../images/laurie-header_08-laurie-hea.gif");
laurie_header_09_over = newImage("../images/laurie-header_09-over.gif");
laurie_header_09_laurie_header_10_over = newImage("../images/laurie-header_09-laurie-hea.gif");
laurie_header_10_laurie_header_09_over = newImage("../images/laurie-header_10-laurie-hea.gif");
laurie_header_10_over = newImage("../images/laurie-header_10-over.gif");
laurie_header_10_laurie_header_11_over = newImage("../images/laurie-header_10-laurie--24.gif");
laurie_header_11_laurie_header_12_over = newImage("../images/laurie-header_11-laurie-hea.gif");
laurie_header_11_laurie_header_10_over = newImage("../images/laurie-header_11-laurie--27.gif");
laurie_header_11_over = newImage("../images/laurie-header_11-over.gif");
laurie_header_12_over = newImage("../images/laurie-header_12-over.gif");
laurie_header_12_laurie_header_11_over = newImage("../images/laurie-header_12-laurie-hea.gif");
laurie_header_12_laurie_header_13_over = newImage("../images/laurie-header_12-laurie--32.gif");
laurie_header_13_laurie_header_14_over = newImage("../images/laurie-header_13-laurie-hea.gif");
laurie_header_13_laurie_header_12_over = newImage("../images/laurie-header_13-laurie--35.gif");
laurie_header_13_over = newImage("../images/laurie-header_13-over.gif");
laurie_header_14_over = newImage("../images/laurie-header_14-over.gif");
laurie_header_14_laurie_header_13_over = newImage("../images/laurie-header_14-laurie-hea.gif");
laurie_header_15_laurie_header_14_over = newImage("../images/laurie-header_15-laurie-hea.gif");
laurie_header_16_laurie_header_09_over = newImage("../images/laurie-header_16-laurie-hea.gif");
laurie_header_16_laurie_header_14_over = newImage("../images/laurie-header_16-laurie--44.gif");
laurie_header_16_laurie_header_12_over = newImage("../images/laurie-header_16-laurie--45.gif");
laurie_header_16_laurie_header_10_over = newImage("../images/laurie-header_16-laurie--46.gif");
laurie_header_16_laurie_header_11_over = newImage("../images/laurie-header_16-laurie--47.gif");
laurie_header_16_laurie_header_13_over = newImage("../images/laurie-header_16-laurie--48.gif");
preloadFlag = true;
</SCRIPT>nextupdate_laurie_header_09_over = newImage("../images/nextupdate-laurie-header_09.gif");
preloadFlag = true;
</SCRIPT>I know absolutely nothing about java, but I was wondering if anyone could determine if this site was indeed using code to block the use of PicaLoader. Sure seems like it to me. A few months ago, I was able to get it to work, but now it seems blocked. Stumped on this one.
Thanks.
