is it possible to download all pictures of one folder
Posted: Wed Oct 08, 2008 8:57 am
by venga1
Suppose there is
www.site.com/images/imagefolder/
ok the imagefolder is not directly accessed through browser...means apcahe setting not to list the file
now is is possible to download all the images of imagefolder
the images of the imagefolder are used normally in php page using <img src tags..
any help?
any tweak..?
is it possible with the picalodaer?
Re: is it possible to download all pictures of one folder
Posted: Wed Oct 08, 2008 2:09 pm
by KoalaBear
PicaLoader can follow php page to download pics.
If a picture not linked by any web page, there is no way to download it, except you know the picture's filename.
Posted: Mon Nov 03, 2008 7:07 pm
by dado
you say :
i have it. i mean all names of files in directory. real example of files names :
so , so different names, it is hard to make a substitute by picaloader functions, because no continuity of values :
789542.jpg is real filename, but 789543.jpg, 789544.jpg or 789541.jpg, 789540.jpg doesnt exists.
but, i have a list of all names of files and they are stored in my xls spreadsheet file ( in rows ) - so every name in a single cell , row by row.
what now ? can picaloader read some extended xls or txt or csv or .... file ?
Posted: Tue Nov 04, 2008 2:04 am
by KoalaBear
try this way:
1.open your excel file, add a row before filename row, fill with start, fill the row after filename row with end. (like attached picture)
2.save as .csv file.
3. open .csv file with a text editor, like notepad, replace all:
start, with <a href='http://www.site.com/images/imagefolder/
,end with '>pic</a>
4. rename .csv file's ext to .htm
5. run picaloader, open a project, create a new task, start URL:
file://[full path of your .htm file], e.g. file://e:\test.htm
that's all:)
Posted: Tue Nov 04, 2008 7:58 pm
by dado
thank you for quick response, but not work corect. in list is cca 15000 rows = 15000 pictures, but only cca 3600 were saved. i do not know what is incorrect, or what is my mistake.
in attachment are both files : XLS + my final file HTM.
OPTION panel is in attached picture.
Posted: Wed Nov 05, 2008 1:12 am
by KoalaBear
you can switch to Report to check out what happened. maybe the web server is overload, the downloading is timeout.
you can click Move All to Queue then start downloading again to retry download these error URLs.
Posted: Wed Nov 05, 2008 8:19 pm
by dado
no error warnings, but thanks a lot ! i just tried uninstalled from c:\program files\picaloader and installed to only c:\picaloader. i am no IT admin, but this help me and everything is working like you wrote first. some read/write error or something like this, i dont know... but now it works.
before my question i have read some more topics ( not only one or two ), and now can i say with peace in my mind : everything is possible with you - you are a woodoo master !
i am very greatful !!!
have a nice day from Slovakia
