'Can't get the file'
While trying to download some pictures I get the error message 'Can't get the file'. The URL looks the following way for example:
http://www.xxxxxxx.de/PP3CC/large.htm?t ... eight=1024
Does anybody know the problem?
PM
PM
Click on View - Options - Download.
I usually change "Pause between connections" from 3 to a higher value. One site I rip usually works pretty good at 10-11 seconds. You'll have to play around with it to see if it makes a difference and whats the lowest number you can get away with(fastest).
However, since installing 1.47, when I change this I don't see PL pausing like it did in 1.46. So I think its broke in 1.47.
This option effects every project so remember to put it back to 3 after you're done.
I have the same problem - I upgraded in order to resolve the issue where the program crashed when I tried to pause the project (this issue was related to XP SP2) and now I get the "'Can't get the file'" error every time.
Also when I click on the error report button nothing happens - presumably due to new security settings in Internet Explorer.
I managed to find the report file and launch it manually - I then had to temporarily change my security settings to allow the report to display.
Anyway - having upgraded to version 1.47.0909 I can no longer download any pictures from the site that had been working fine.
Help!
Help!
In my case the urls are definitely valid. They are password protected but everything was working fine before i upgraded (apart from the program crashing on Pause which was why I upgraded).
I tried uninstalling the program completely and reinstalling the latest version and I also started a new project from scratch in case something had been corrupted.
Still getting the error message on valid urls.
Same here, I assume its a dummy url.KoalaBear wrote:I click the URL you list above and got HTTP 404 - File not found.
Question for the people having problems: Is PL working at all? Or are you just getting errors intermittantly?
If PL isn't working at all, do you have a firewall or XP SP2. It maybe a firewall issue.
