Can anyone help me create a project file to download all the girls of maxim and create separate folders for each girl.
www.maximonline.com/girls_of_maxim
Try this file.
Maxim stores their images in folders named after each model so I used "recreate website structure" in the projects properties.
The Girls of Maxim Task uses "Batch download numbered sequence URLs". I have set it to download all the girls as of today [1-1078] but you might want to modify it to only do 100-200 at a time or maybe the first 10 to view the results.
After doing a complete download, you should modify the task URL as neccessary to download only the latest images. Doing so will decrease the time it takes run and it won't have to analyze the links all over again. I think the site updates on a monthly basis.
- Maxim Girls.plp
- (26.62 KiB) Downloaded 3398 times
Thanks but I have a new problem now
The project file looks fine but I get a disk space is less than limit error after a few minutes of running it. I have 12 gigs of space so I am not sure what the problem is.
You're the second person to have this problem on two different project files I've uploaded. Not sure what the problem is. In both cases I was using the version 1.47.0826.
Make sure you're running that version. Might also want to check that setting on the Options dialog box. And maybe Optimize the database. Does the error occur if you only run the Girlfriend task?
Thanks for the Quick Response
Thanks for getting back so quickly. I couldn't find the same version of picaloader you were using. I was using 1.47.0909 so what I did was create the project exactly like you had it and it worked.
Thanks again for the help,
