Post new topic Reply to topic  [ 13 posts ]
 Post subject: How to download from Mangafox
 Post Posted: Thu Oct 16, 2008 3:03 pm
CAn tell me how to grab a full manga episode picture from http://www.mangafox.com/ using picaloader in separated folder??
thanks
 Post subject: Re: How to download from Mangafox
 Post Posted: Fri Oct 17, 2008 2:04 am
hmmm, another great manga site:)
We can also create a new PicaLoader project for only download pictures from this site, you can check Create subfolder for each task if you want save organize manga by folder, and check Orignial Filename if you want keep the pic's filename.
Then set the project's default settings:
Page Location: Within current directory & deeper
Enter Page URL Include Filters:/c[\d\.]+/$;\d+\.html$
Enter Picture URL Include Filters:/compressed/
OK!, now we can visit http://www.mangafox.com/directory/ with IE, drag the manga that you wanna download and drop to PicaLoader's drop box, PicaLoader will create a new task for you, just press OK button.
Now you can press Start button or add another task by drag and drop.
 Post Posted: Thu Oct 23, 2008 11:48 pm
Hi, i'm new here and i found this topic, i tryed it and it worked, but i got a question, it downloaded all the pictures in a folder named like the manga, but i want them to be separated in diferent folders acording to the chapter all of them inside the folder named after the manga title, is that possible?
by example
and
 Post Posted: Thu Oct 30, 2008 9:48 pm
Hi, Im new here too and Im so glad to know such a great way to download from my fav manga site. However, could you show me the way to download each chapter only, not whole the series, pls? Tks a lot.
 Post Posted: Sun Nov 02, 2008 8:35 am
Wow, I found the way to download each chapter already, just drag the manga chapter that you wanna download and drop to PicaLoader's drop box, PicaLoader will create a new task w manga chapter name for you, just press OK button, and it's done. EXCELLENT!!!
 Post Posted: Wed Jan 28, 2009 12:40 pm
i'm able to dwl the manga from mangafox. However, all my pictures are randomly named and thus, making it near impossible for me to read it in sequence. I'm using create sub folder for each task. Even when i change the picture filename from unique filename to customize filename: PATH+FNAME+EXT, it just then changes into one picture per folder.
All i'd like to achieve is to make the pictures from the same manga chapter be in the same folder with the folders and the pictures in right number sequence so that i at least know which one to read first.
I've tried almost everything but i'm still unable to figure my own way out. I'd really appreciate it if someone could help me! Ty! :)
Here's my file just in case u'd like to check it.
mangafox.plp [16.87 KiB]
Downloaded 830 times
 Post Posted: Wed Jan 28, 2009 2:43 pm
Just change Picture Filename to Original Filename
 Post Posted: Thu Jan 29, 2009 6:05 am
Sorry!! But it DID get named with numbers, but then, lots of the pictures are just named like 00, 02 and so on, it's not in sequence and thus, it's really hard to read.
Is there a way to put one chapter per folder? then it will be easy to read. Or i'll have to slowly drag each chapter?
 Post Posted: Tue Feb 17, 2009 11:27 am
I think the manga fox web structure have been change. So when I try to download, it get only one page from each chapter. So please help me.
 Post Posted: Wed Feb 25, 2009 11:44 pm
I have same problem, So please help.
 Post Posted: Sat Apr 11, 2009 4:14 am
Please need help!!!!
 Post Posted: Wed May 27, 2009 11:31 am
im still finding a best way to download ...
_________________
affordable SEO companies | thatcom
 Post Posted: Fri Jun 12, 2009 9:54 am
the site structure changed, it easilly than before:)
I changed my 1st post in this article, please check it.
Users browsing this forum: No registered users and 0 guests
